Element quality
Old   December 6, 2006, 07:59
Default Element quality
Andreas
Hello, I have a more general question concerning the mesh generation. However since I am using CFX I will post it here.
I know that it is important to generate elements with a "quality" as high as possible (e.g. for CFX at least 0.15, if possible). I also know that "high quality" means that the angles of the elements are supposed to be as good, i.e. as similar as possible (Prism 90deg, Tetra 60deg, etc), right?
What I do not understand is simply the reason. If I am using a CV-approach (like in CFX) my equations will be "made out of" expressions including CV-face-points. But why is it important to have faces that are oriented towards each other as similar as possible?
Regards Andreas
Old   December 6, 2006, 09:07
Default Re: Element quality
Joe
Avoiding excessive numerical diffusion amongst other things.
Old   December 7, 2006, 09:14
Andreas
Alright, thank you.But what role play the element angles for numerical diffusion? If the answer is too lenghty for this forum I would be very pleased to get the titles of some good textbooks/references that deal with the issues of control volumes and element quality.
Thanks and regards Andreas
[Gmsh] gmshToFoam unhandled element flowris OpenFOAM Meshing & Mesh Conversion 4 February 20, 2023 17:50
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
Tetras, Prims, BL-resolution and element quality fonzie CFX 2 November 30, 2009 03:33
Generate allHex mesh element quality hsieh OpenFOAM Running, Solving & CFD 3 May 31, 2006 13:38
