[Sponsors] | |||||
Frank Weise
Rep Power: 18 ![]() |
I have an electric resistance heater. First of all, I simply approximated this as an imprinted heat output. Unfortunately, I have found that there is probably a temperature dependency that cannot be neglected. Is there a simple way of making the impressed power dependent on the temperature?
I am currently using a subdomain with a heat source as a heater. regards Frank |
Erik
Rep Power: 24 ![]() |
Sure. Just make volumetric heat a function of temperature using the CFX expression language or a user function:
VolHeatExample = 100[W/m^3] + 5[W/m^3/K]*T. You could also use an electric model, and have variable electrical resistance, and define a current or voltage on the conductor ends (see tutorials). |
Frank Weise
Thanks for the tip. I also came up with this type of solution yesterday. I wanted to avoid the electric model because of the effort involved.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
| [foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
| [Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
| [swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
| Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
