Thin Surface not taken
Old   December 8, 2006, 20:38
Default Thin Surface not taken
Maria Angelica
Hello! I am simulating a combustion chamber and the guide vanes in the inlet are set as a wall. When I simulate it, the flow doesn't take this condition and the flow goes through this surfaces. I have tried several ways, but it says in the out file that the boundary condition is a wall in the vanes, but the stream lines and everything are not consistent with this..
Does somebody have had this problem? What could be causing this? I have tried with the option of thin surface and with out this option and i get the same problem.
Any sugestion would be very appreciated!
Thanks!
Maria Angelica
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
