iif_set_lock: file zFas3A4b is currently locked for writing
Old   February 24, 2021, 08:32
Default iif_set_lock: file zFas3A4b is currently locked for writing
Peter Hammond
Hammond is on a distinguished road
Hi there,
I am pretty new to ANSYS CFX, and I have been using it for my dissertation topic. As such, I have been modelling the smoke plume from a ships exhaust in a crosswind and attempting to get the transient results.
I have been getting the error as in the attached pictures. Unfortunately I have to use OneDrive to store the transient results as i am assigned very limited storage space on the machine from the University.
What is causing this error and is there any way I can fix this?
If not, how can i view the results that have been calculated up until this error happens.
Thanks,
Peter
Hammond is offline   Reply With Quote
Old   February 24, 2021, 08:56
Gert-Jan
Gert-Jan will become famous soon enough
Have you managed to run a real small calculation (steady state?) on the local hard disk?
Then I can't think of any other reason than One Drive.
If so, tell your supervisor/professor/teacher that this is not going to work.
Gert-Jan is offline   Reply With Quote
Old   February 24, 2021, 09:43
Peter Hammond
Running small calculations seems to be fine using OneDrive. It's when I try do a long run with many timesteps that i get the issue.
Old   February 24, 2021, 11:56
Opaque will become famous soon enough
By any chance, are you monitoring solution data with CFD-Post while the calculation is proceeding?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   February 25, 2021, 05:33
Peter Hammond
No, I just have solution monitor open on "Display Monitors"
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
