November 16, 2009, 06:09 |
Force by buoyancy
Rep Power: 16 |
Dear all,
The difference in Buoyancy forces switched on or off have a major influence on the forces in my bouyancy direction of my model. For that reason I modelled a simple isothermal, single phase 2D cylinder flow, but still the buoyancy has a major influence. When switched off I get a drag force of -0.33N and when switched on I get a drag force of 0.70N. Epecially the negative drag force is very weird, anyone an explanation? |
November 17, 2009, 06:09 |
Rep Power: 16 |
nobody an idea?
November 17, 2009, 10:54 |
Rep Power: 16 |
found the answer: pressure build op due to the domain (to small)!
November 17, 2009, 20:00 |
Rep Power: 143 |
For future reference: The reason you got no replies is because you did not provide sufficient information about what you were doing and any error messages, convergence histories or anything to debug the problem. We are not mind readers. So I just don't bother answering questions which are poorly asked. I have better things to do.
November 18, 2009, 03:07 |
Rep Power: 16 |
thanks for the tip!
buoyancy, drag |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 07:07 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
pressure force and viscous force | CFD | FLUENT | 0 | March 7, 2006 01:03 |
buoyancy force due to concentration difference | arsei0707 | Phoenics | 1 | December 14, 2005 05:11 |
