FINMES Error - Fatal Overflow in linear solver |
January 10, 2007, 08:43 |
I am trying to simulate Non-premixed Turbulent combustion of Methane-Air Mixture using Finite Rate Chemistry model. When I initialize the domain with low temperatures, the solver runs to a converged solution but the reaction does not ignite. When I initialize the domain to a higher temperature (900 K) as suggested in the manual, I get the following error "FINMES Error - Fatal Overflow in linear solver". The same .def file works absoultely fine when EDM model is used and gives good results. But when I use Finite Rate Chemistry model, this error occurs.Even attempting to start the run from a converged EDM solution does not help All my mesh statistics like Edge length ratio, connectivity, Min.Face angle etc are well below the suggested values in the manual. No. of hexahedral elements are about 25000. Can anybody throw light on where I could be making a mistake? Thanks Jacob |
About Solver Overflow | Felix | CFX | 10 | October 27, 2010 17:00 |
free C code for large sparse matrix linear solver | ztdep | Main CFD Forum | 7 | May 24, 2007 14:14 |
Linear Iterative Solver + Elliptic PDE | cfd101 | Main CFD Forum | 0 | November 14, 2005 18:59 |
linear solver overflow | peggy | CFX | 1 | February 8, 2001 01:39 |
solver for linear system with large sparse matrix | Yangang Bao | Main CFD Forum | 1 | October 25, 1999 04:22 |
