[Sponsors] | |||||
CFD Cong. Heat Transfer Turbine Stage ASS_GLOBCS_IAP |
Ivan
Rep Power: 14 ![]() |
I would like to ask you about error in CFX for Cong. Heat Transfer. After some iterations I got ASS_GLOBCS_IAP message and solution crashed. Task type: CHT, Turbine Stage, solid and fluid parts inlet: Total Pressure, Total Temperature, k-omega SST, rpm (revolution per minute) Total Pressure and RPM are function of time and there are a few operation points - 16 operation points. outlet: static pressure there is cong. heat transfer between some parts and on outer wall there is heat transfer coefficient and bulk temperature. Periodic turbine stage is connected via Mixing Plane and top part part turbine stage is connected with solid part via Frozen rotor. ERROR will happen in the same iterations for repetitions of the same BC or for different conditions in different iterations but it will crash. Please does somebody know what can be cause of the error. Thank you and regards, Ivan ================================================== ==================== OUTER LOOP ITERATION = 776 CPU SECONDS = 3.116E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ Parallel run: Received message from slave ----------------------------------------- Slave partition : 6 Slave routine : ASS_GLOBCS_IAP Master location : Message Handler Message label : 002100088 Message follows below - : +--------------------------------------------------------------------+ | ERROR #002100088 has occurred in subroutine ASS_GLOBCS_IAP. | | Message: | | Could not invert control surface Ap at the following location: | | Domain Interface : periodic_tw_fluid | | Location (X,Y,Z) : ( 0.68127E-03,-0.11068E-01, 0.18306E-01) | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine MESG_RETRIEVE. | | Message: | | Stopping the run due to error(s) reported above | | | | | | | | | | | +--------------------------------------------------------------------+ |
Rep Power: 5 ![]() |
Hello,sir, have you solved this problem? I meet the same problem when I am doing a conjugateheattransfer project. After 600 itrations, it breaks out and shows this message. Could you help me to give some advice? Thank you so much!
| ERROR #002100088 has occurred in subroutine ASS_GLOBCS_IAP. |Message:Could not invert control surface Ap at the following location: Domain Interface: A21_Comp_R1 to A21_Comp_R1 Internal 2 |Location (XY,Z) : ( 0.46967E-02,-0.38904E-01, 0.61605E-01) |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem with total heat transfer rate | aswathy_raghu | FLUENT | 9 | April 21, 2022 11:36 |
| Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
| Problem with total heat transfer rate | aswathy_raghu | FLUENT | 0 | July 26, 2016 08:39 |
| Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
| heat transfer conjugated CFD | wildli | FLUENT | 2 | May 16, 2011 16:58 |
