FINMES Error - Fatal Overflow in linear solver
Old   January 10, 2007, 08:43
Default FINMES Error - Fatal Overflow in linear solver
Jacob
I am trying to simulate Non-premixed Turbulent combustion
of Methane-Air Mixture using Finite Rate Chemistry model.
When I initialize the domain with low temperatures, the
solver runs to a converged solution but the reaction does
not ignite. When I initialize the domain to a higher
temperature (900 K) as suggested in the manual, I get the
following error "FINMES Error - Fatal Overflow in linear
solver". The same .def file works absoultely fine when EDM
model is used and gives good results. But when I use Finite
Rate Chemistry model, this error occurs.Even attempting to
start the run from a converged EDM solution does not help
All my mesh statistics like Edge length ratio,
connectivity, Min.Face angle etc are well below the
suggested values in the manual. No. of hexahedral elements
are about 25000. Can anybody throw light on where I could
be making a mistake?
Thanks
Jacob
About Solver Overflow Felix CFX 10 October 27, 2010 17:00
free C code for large sparse matrix linear solver ztdep Main CFD Forum 7 May 24, 2007 14:14
Linear Iterative Solver + Elliptic PDE cfd101 Main CFD Forum 0 November 14, 2005 18:59
linear solver overflow peggy CFX 1 February 8, 2001 01:39
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 04:22
