January 30, 2007, 04:30 |
Paralisation in Windows XP
My university has win licenses for cfx and we need to work in windows. Now i wanna know when I use paralelisation in windowas what i gat in speed becouse we run normal LAN 100mb network. Is this too slow or we can try to work with that. Problem is that my simulation run on local machine for 2-4 days depending on variables and we run 300000 elements mesh. The proble is that i need 3-4 mil elem for my simulation. What to do? Zoran Karabaic |
January 30, 2007, 04:33 |
PARALELISATION -sory
January 30, 2007, 08:09 |
Re: PARALELISATION -sory
I doubt 100 mb is going to cut it. I would suggest 1 gbps is a minimum requirement.
January 30, 2007, 08:17 |
ok, nothing than cause the LAN is only 100mbps.
Thanke you |
January 30, 2007, 16:10 |
Re: PARALELISATION -Yes!
Sorry Joe, but I think you are wrong. My testing of 100mb versus gigabit ethernet has shown there is very little difference. I have run 100MB ethernet for years with good parallel speedup. I am now running everything on Gigabit ethernet but it sped things up by only about 1-2%, not really significant. In my experience with CFX there is little point getting anything more than basic 100MB or gigabit ethernet as the speedup from the network side of things is small. I have tested up to 8 node parallel. I suspect when you start talking about 16 nodes or more the network becomes more important and you need to look at more specialised networks, but for small clusters (8 nodes or smaller) 100MB ethernet will work fine. Zoran, don't worry, your 100MB network will work fine. What will be more important is the reliability of the network. Network outages will kill your jobs and this becomes very annoying. Glenn Horrocks |
January 30, 2007, 16:27 |
I stand corrected then. Never worked on clusters with less than gigabit links.
January 31, 2007, 03:17 |
Thank you Glenn,
I'll try paralelisation next monday cause i need to make some preparations first, and learn how to do that. My network is wery goog and is working great, newer shout down. Do you have some tips on what to do or some parts what to look up ? Zoran |
January 31, 2007, 08:06 |
One thing to consider is to use a private or local network. You probably don't want to share traffic with other things, like email, data transferring, etc.
February 1, 2007, 03:11 |
Oh, network is local, and is blocked to all outside trafic. So next weak i'll gona try it.
Thanke you all Zoran |
Fluent and Gambit on Windows 7? | gholamghar | FLUENT | 12 | July 10, 2012 10:42 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
