Turbo Grid 10.0 installation in Linux
Old   February 3, 2007, 09:02
Default Turbo Grid 10.0 installation in Linux
VikMan
I am facing the following error when I try to run turbogrid in my linux machine:
/usr/software/TurboGrid-10.0/bin/linux/TGGui_ogl.exe: /usr/software/TurboGrid-10.0/lib/linux/libgcc_s.so.1: version `GCC_3.3' not found (required by /usr/lib/libstdc++.so.6) Warning!
CFX-TG exited with return code 1
Can someone help me in this regard? Other CFX suite of software, i.e., CFX-Pre Post and Solver are working fine.
Regards, Vik
Old   February 3, 2007, 10:50
Default Re: Turbo Grid 10.0 installation in Linux
Joe
This worked for me:
From: http://polymerfem.com/modules.php?na...article&sid=72
Fix: cd /home/CFX-10.0/lib/linux-amd64/ mv libgcc_s.so.1 libgcc_s.so.1.BACKUP
Old   February 8, 2007, 07:21
VikMan
Hi Joe,
Thanks for your response.
I couldn't locate the folder that you have mentioned in your message. I tried to locate a file with a similar name. I found it in /lib folder. Inspite of making the change TG didn't work. Right now I am trying some other things. Meanwhile could you tell me where these files would be located on a Red Hat Linux 3.4 version?
Thanks for all the help.
Best Regards, Vik
Old   February 8, 2007, 07:37
VikMan
Hi Joe,
I backupped the files in the CFX library and TG 10.0 library. It doesn't seem to work the new error I am getting is:
/usr/software/TurboGrid-10.0/bin/linux/TGGui_ogl.exe: error while loading shared libraries: libgcc_s.so.1: cannot open shared object file: No such file or directory Warning!/usr/software/TurboGrid-10.0/bin/linux/TGGui_ogl.exe: error while loading shared libraries: libgcc_s.so.1: cannot open shared object file: No such file or directory Warning!
CFX-TG exited with return code 127
I still can't find a solution.
Thanking you in anticipation.
Best Regards, Vikram
Old   February 8, 2007, 09:54
Joe
Odd. All I know is that the fix I posted was due to a recent RHEL 4 bug ... perhaps the fact that you are using 3.x makes my fix irrelvant to your problem. I suggest you contact CFX support directly.
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 04:29
CRITICAL ERROR on installation OpenFOAM 141 nuovodna OpenFOAM Installation 19 March 22, 2010 22:36
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation hints OF141 on openSUSE103 markc OpenFOAM Installation 1 February 15, 2008 06:58
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
