transition onset - SST:Gamma Theta Model
Old   February 6, 2007, 02:52
Default transition onset - SST:Gamma Theta Model
Prad
Hi, am having problems with ascertaining my
TRANSITION ONSET CORRELATION: Option = User Defined Transition Onset Reynolds Number = 260.0*(1.0+x/(1.0[m]))
Cant seem to figure out what happens when I change values. Maybe I've overlooked some thing. I've tried variations but they're all larger by approx. factor 2 when compared with my experimental (Ca vs. Cw plots for various angles)data. What is the influence of inlet conditions (eddy viscosity etc)? Other approaches (Langtry Menter) do not bring better results. There's very little background available. Maybe someone here works with tra- onset regularly. Any suggestions are welcome. Gracias Prad
Old   February 8, 2007, 13:34
Default Re: transition onset - SST:Gamma Theta Model
Chebeba
Inlet turbulence influences transition onset to a very large extent, at least for Langtry Menter.
Old   February 20, 2007, 10:47
Adam
Sensitivity to inlet conditions are indicitave of the gamma theta model structure in general. Mostly Tu and viscosity ratio.
What are you modelling and how, what is your grid stats, where did you get your correlation for retheta?
Adam
Old   February 21, 2007, 06:24
Prad
Hi Adam, have an Eppler profile, all boundaries are 4~5x distant from the foil (2cells deep), y+ around 1, have now switched all values to default values. Drag is influencing my polar which is straying from experimental values.Thanks for further info Prad
Old   February 21, 2007, 09:32
Adam
Prad,
Not sure what you mean. Could you please give me more information before I can help you.
Thanks
Adam
Gamma Theta model and underpredicted lift Nick R CFX 29 July 22, 2011 00:03
SST Transition model in Fluent 12.0 Far FLUENT 1 November 8, 2010 01:32
anybody's done airfoil model with transition? Hao CFX 3 March 11, 2009 21:31
Re: Transition Model Michael K H Kim Main CFD Forum 1 September 23, 1999 13:30
k-omega model and unsteady transition Jens Thurso Main CFD Forum 1 May 4, 1999 09:50
