CFX5Post error in batch mode with Perl
I want to write a short perl programm with CFX Post session file, but is alway take about 2 min to run the command, and finally gives a error message like:
--------------------------------------- ERROR in WriteToken: Writing token key ERROR in WriteCommand: Writing command key ERROR in WriteToken: Writing token key ERROR in WriteToken: Writing token key ERROR in WriteCommand: Writing command key Use of uninitialized value in concatenation (.) or string at (eval 21) line 1. Batch run of "./getprofile.cse" failed due to the following errors: -- ERROR -- Connection timeout after 120s -- ERROR -- CCL parser failed with message: invalid parameter name: must be non-empty. ERROR in WriteCommand: Writing command key The session file is generated by CFX POST, so there are clearly no errors, and when I cut the perl codes I added and run that part from command line only, it also gives correct answer. What is the problem, my OS is SuSe Linux, please help, thanks in advance. |
Re: CFX5Post error in batch mode with Perl
I have a very similar problem when trying cfx5post -batch <filename>.cse And the session file was recorded straight from cfx post using the gui. Any ideas?
Thanks |
Did you manage to solve your problem? if so could you help me?
regards Jon |
