March 1, 2007, 11:45 |
overflow error on linux cluster
hi,
I am conducting a compressible CFX10 simulation. The weired thing is, the simulation runs ok on the local PC, but always fails on linux cluster. The error information is overflow. How to fix it? Thanks a lot Equation | Rate | RMS Res | Max Res | Linear Solution | U-Mom | 0.00 | 1.3E-12 | 3.7E-11 | 4.7E+08 F | V-Mom | 0.00 | 9.2E-12 | 1.5E-10 | 2.4E+08 F | W-Mom | 0.00 | 3.6E-12 | 7.2E-11 | 6.3E+08 F | P-Mass| 0.00 | 4.2E-22 | 2.0E-20 | 9.3 4.5E+08 F | ERROR #001100279 has occurred in subroutine c_fpx_handler: Floating point exception: Overflow |
March 13, 2007, 08:05 |
Re: overflow error on linux cluster
Could be due to partitioning. To confirm, try running on the linux cluster using the same number of partitions as the local PC. If that works, then look at where your partition boundaries lie on the case that fails.
Linux Cluster Manager from SGI out for X86 | Shelly Zavoral | Main CFD Forum | 0 | February 13, 2009 12:26 |
LINUX cluster and server | azmir | Siemens | 6 | September 17, 2006 19:09 |
Linux Cluster Performance with a bi-processor PC | M. | FLUENT | 1 | April 22, 2005 09:25 |
Linux Cluster Setup Problems | Bob | CFX | 1 | October 3, 2002 18:08 |
