Droplet boundary layer
Old   March 14, 2007, 08:20
Default Droplet boundary layer
Neser25
Any one know, how to simulate falling droplet on a vertical wall (boundary layer study + heat and mass transfer study) IN CFX 10
Regards
Old   March 14, 2007, 12:49
Default Re: Droplet boundary layer
Joe
Just getting the cold flow model right would require carefull validation against experimental data. Surface tension effects on real surfaces are notoriously finicky e.g. composition, contamination, roughness, ...
If you dont have good experimental data to validate against, you are going to have to do that first anyway, which may make using CFD redundant.
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
[GAMBIT] problems in boundary layer yubaibai88 ANSYS Meshing & Geometry 8 April 19, 2010 21:07
3D Boundary Layer Mario FLUENT 0 February 17, 2009 03:40
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 07:23
