Applying Shear Stress at a Boundary Condition
Old   March 27, 2007, 12:53
Default Applying Shear Stress at a Boundary Condition
Stephen
Hello Everyone,
I am attempting to apply a constant shear stress to an opening boundary condition and have been at a loss in how to specify this in CFX. Does anyone know how to implement this boundary condition? I am using CFX 11.0
Thanks in advance, Stephen
Old   March 27, 2007, 14:03
Default Re: Applying Shear Stress at a Boundary Condition
opaque
Dear Stephen,
That boundary condition type is not implemented in ANSYS CFX..
Would you mind sharing what that BC models at an opening? I can see it for a wall (like wind on a free surface), but not for open boundaries..
Thanks,
Opaque
Old   March 27, 2007, 14:44
Stephen
Thanks for the reply Ppaque,
I am modeling the surface layer of the atmospheric boundary layer. Throughout the surface layer there is a constant shear stress equivalent to the density*friction velocity. This model will eventually be applied to modeling flow over bluff bodies within the surface layer. In order to take into account the shear stress from the flow above the domain, a constant shear stress must be applied to the top of the domain. Also, implementing an opening would not constrain the flow from entering and leaving the domain if required with the increase in the pressure due to the bluff body. I know it is possible to specify a velocity of the flow on an outlet and thus generate a shear stress on the flow but this seems like the backward method to solve the problem.
This type of boundary condition is also sometimes implemented when modelling flow impinging on a plate, when taking the effects of the surroundings on the radiating fluid.
I though there may be a way to implement this boundary condition through a user CEL function.
Stephen
Old   March 27, 2007, 18:55
Can't you then work out the velocity distribution from the known shear stress? You can then apply the velocity distribution as an inlet boundary. CFX would work with this approach.
Shear Stress Calculation in the flow. auburnuser FLOW-3D 11 May 12, 2018 13:49
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
No Slip / 0 shear Boundary Condition evan FLUENT 0 July 29, 2004 13:37
