CFX High Performance Computing solver-mpi. exe not found
Hi everybody,
I am experiencing a strange error when trying to run a simulation on our university's HPC system. The job is started by running a batch file with the following command line: Code:
/ANSYS/v193/v193/CFX/bin/cfx5solve -batch -double -def cal18.def -parallel -start-method "Intel MPI Local Parallel" -part 36 -monitor CFX_001.out Code:
An error has occurred in cfx5solve: Has anybody experienced similar issues or has an idea what is messed up here? A workaround that came to my mind is to specify the required solver-mpi.exe with its root within the batch file....Not sure, if this is gonna work. Thanks in advance, Sundriver |
