March 12, 2007, 07:22 |
CFX Error Message
I trying to run a transient sloshing simulation in CFX 5.7, however I keep getting the following error:
Error detected by routine PEEKCS CDANAM = BCP3/VARIABLES/VEL_/BCTYPE CRESLT = NONE ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine MEMERR Can anybody explain this please? I guess it is something relating to the velocity and boundary conditions. However, I have only a pressure outlet and initial velocities are all zero. Movement is initiated by harmonic oscillating sway accelerations though CEL Expressions. Thanks Lindsey |
March 12, 2007, 08:38 |
Re: CFX Error Message
Your CEL expressions and/or routines contain an error. They are calling a non existent variable.
March 12, 2007, 11:45 |
Joe,
My expressions are as follows: CEL: EXPRESSIONS: DensityH = 998 [kg m^-3] HydrostaticPressure = DensityH*g*VFH2O*(InitialHeight-y) InitialHeight = -.071 [m] VFAir = step((y-InitialHeight)/1[m]) VFH2O = 1-VFAir XAmplitude = 0.01 [m] XFrequency = 1 [s^-1] XOmega = 2*pi*XFrequency XSway = -XAmplitude*(XOmega^2)*sin(XOmega*t) YSway = -g END CFX seems happy with them in pre, either returning a value or the plot that would otherwise be expected. I have no routines running that I am aware of...? Can you see an error in that? |
March 12, 2007, 16:17 |
The function calculating HydrostaticPressure calls the variables VFH2O and InitialHeight which are not defined but are defined later. Move the calculations of VFH2O and InitialHeight to before this line. Regards, Glenn Horrocks |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
