Single Bubble
Old   March 11, 2007, 12:02
Default Single Bubble
Gerrit Senger
Hi!
I'm working on a simple problem (at least it seems simple): I want to create a single air bubble which is initialised in a rectangular shape in water and then formed to a nice ball by surface tension force. So far, so good.
The spherical ball-form is created properly, but my problem is, that the bubble is rising although I aet "non-buoyancy". I even set "bouyancy" with "0 buoyancy" to all three axis and then "non-bouyancy" for both fluid (otherwise there would be density bouyancy)....
It's very amazing why the bubble is rising while there are no bouyancy forces.... Maybe anybody could help me or give me an advise.
Here are all interessting files: ftp://www.aquaria-zehlendorf.de/cfx/all.rar
LIBRARY:
CEL:
EXPRESSIONS:
xlim = 1.E-3[m]
ylim = xlim
zlim = xlim
airvf = \
step(step((zlim-abs(z))/1[m])*step((ylim-abs(y))/1[m])*step((xlim-abs\
(x))/1[m])-0.51)
END
END
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
Thermal Expansivity = 0.003356 [K^-1]
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
Thermal Expansivity = 2.57E-04 [K^-1]
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
END
END END EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: laptopgerrit
Installation Root = C:\Program Files\Ansys Inc\CFX\CFX-%v
Host Architecture String = intel_pentium_winnt5.1
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = D:/Diplomarbeit/CFX/10.3.07/10.3.2007.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
Runtime Priority = Low
EXECUTABLE SELECTION:
Double Precision = On
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END FLOW:
DOMAIN: blase
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air at 25 C,Water
Location = AIR,WATER
BOUNDARY: symm
Boundary Type = SYMMETRY
Location = ISYMML,ISYMMR,SYML,SYMR
END
BOUNDARY: aussen
Boundary Type = OPENING
Location = BOT,TOP,WALL
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Static Pressure for Entrainment
Relative Pressure = 0 [Pa]
END
END
FLUID: Air at 25 C
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
FLUID: Water
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID: Air at 25 C
FLUID MODELS:
MORPHOLOGY:
Option = Continuous Fluid
END
END
END
FLUID: Water
FLUID MODELS:
MORPHOLOGY:
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Homogeneous Model = False
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
FLUID PAIR: Air at 25 C | Water
Surface Tension Coefficient = 0.072 [N m^-1]
INTERPHASE TRANSFER MODEL:
Option = Free Surface
END
MASS TRANSFER:
Option = None
END
MOMENTUM TRANSFER:
DRAG FORCE:
Drag Coefficient = 0.44
Option = Drag Coefficient
END
END
SURFACE TENSION MODEL:
Curvature Under Relaxation Factor = 0.25
Option = Continuum Surface Force
Primary Fluid = Air at 25 C
Volume Fraction Smoothing Type = Volume-Weighted
END
END
MULTIPHASE MODELS:
FREE SURFACE MODEL:
Interface Compression Level = 1
Option = Standard
END
END
SUBDOMAIN: Subdomain 1
Location = AIR
END
END
INITIALISATION:
Option = Automatic
FLUID: Air at 25 C
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic with Value
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
VOLUME FRACTION:
Volume Fraction = airvf
END
END
END
FLUID: Water
INITIAL CONDITIONS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
VOLUME FRACTION:
Option = Automatic
END
END
END
INITIAL CONDITIONS:
STATIC PRESSURE:
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Option = Standard
Time List = 0.0005 [s], 0.0008 [s], 0.001 [s], 0.002 [s], 0.003 [s], \
0.005 [s], 0.006 [s], 1 [s]
END
TRANSIENT RESULTS: Transient Results 2
Option = Standard
Time Interval = 0.005 [s]
END
END
SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 1 [s]
END
TIME STEPS:
First Update Time = 0.0 [s]
Initial Timestep = 0.0001 [s]
Option = Adaptive
Timestep Update Frequency = 1
TIMESTEP ADAPTION:
Courant Number = 2
Maximum Timestep = 0.005 [s]
Minimum Timestep = 5e-06 [s]
Option = MAX Courant Number
END
END
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 4
Minimum Number of Coefficient Loops = 3
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Conservation Target = 0.01
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END
END END COMMAND FILE:
Version = 10.0
Results Version = 10.0 END
Old   March 11, 2007, 12:13
Default Re: Single Bubble
Gerrit Senger
The correct URL is www.aquaria-zehlendorf.de/cfx/all.rar
Old   March 11, 2007, 16:21
Their will be some residual momentum left after the bubble bounces and wobbles from the initial shape to a sphere. This may make the bubble travel slowly in a direction after settling. If the mesh is not even over the width of the bubble this could easily cause a small residual motion.
Also check your timesteps are fine enough and the convergence is tight enough. With finer convergence the residual motion should decrease.
Also, the magnitude of the residual motion should be much less than the motion when buoyancy is activated.
Old   March 12, 2007, 07:32
Gerrit Senger
Thanks a lot for your answer!
Well I have too add that the motion is only in positive x-axis....your advice concerning the cushioned motion by decreasing the timesteps and residuals should help to minimise them, but I think the problem is that this motion in x-axis shouldn't be there at all or at least it should be equalised because of all x,y and z-axis since there shouldn't be any buoyancy. That's why it's very amazing that the residual motion is only affecting the x-axis....
I just hope that this residual motion is really significantly lower than the final bouyancy-rising-motion....
Best regards, Gerrit
Old   March 12, 2007, 16:29
In numerical simulation there is no such thing as "zero". Zero is approximated as a small number, so your bubble which should have zero velocity as the forces should cancel to give no net force actually sum to a small number. Therefore your bubble will have a small velocity.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
VOF single bubble rising velocity! Lincoln Main CFD Forum 3 April 10, 2012 10:04
single bubble simulation. kumar Main CFD Forum 3 May 28, 2006 11:37
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
P4 1.5 or Dual P3 800EB on Gibabyte board Danial FLUENT 4 September 12, 2001 11:44
