Def file
Old   March 25, 2007, 05:18
Default Def file
Neser25
In CFX10, my work is to study the effect of spray parameters on drying process. Therefore, I made some change in CFx pre and re-run again for each parameters I need to study (I did not delete the Def file, I ask the program to over write). I noted that my Def file increases from run to anther run (become about 1.5 Gb). To my surprised, when I deleted the Def file (CfX will create a new one not overwrite) its size become about 9 MB only.
The question is that is I have ti delete it when I made any change in CFX pre and re- run or not? why its size increases? Is that has any effect on my results (CFX results)? if yes then I have to repeat all of my preivous results
Regards
Thank you for your help
Old   April 5, 2007, 09:17
Default Re: Def file
Stumpy
Install Service Pack 1 to fix this. It was a bug, but other than the file size it didn't cause any problems (i.e. your results are OK)
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
