Transient blade row model data instancing for odd number of blades |
September 10, 2021, 02:20 |
Not applicable
Hello everyone,
I searched it in the forum but I did not get anything about this problem. I hope to explain it in a clear way. I am doing a centrifugal fan analysis in CFX using transient blade row model. I am using the fourier transform method. The number of blade of the fan is an odd number (11 let's say). In fourier transformation method, I have to model two blade to sample between the blade passages. So I modeled one blade passage first. Then I increased the number of passages to two using turbo rotation in turbo mode. So I have two blade passages in my simulation. The calculations have been made and everything is fine with my analysis. But the problem is starting at this point. I want to show te result for 17 blades. So I have to use data instancing. But I have 2 blade in my simulation and I have to show the results for 11 blades. The blade number in the analysis is even but the real number of blades is odd. How can I show the results for 11 baldes? Maybe there is a way to do it but I could not find it. I am adding some pictures to explain my problem. Thank you for your help already. [IMG]https://im.ge/i/QJJCb4 https://im.ge/i/QJJEGC[/IMG] |
September 10, 2021, 08:22 |
Rep Power: 32 |
As far as I know, there is no way, so you can either show the 10 blade model and miss one passage, or instance 6 copies (12 blades), and if the solution is well converged the overlap copy should match the first passage.
Have you tried creating the locator on the mesh regions for a single passage instead of using the "physics regions" of the model? That is you can instance the model, and see if the mesh regions are also instanced and check what you can get out of this approach.
September 10, 2021, 09:32 |
Not applicable
Dear opaque,
Thank you for your advice. Actually I tried to inctance as 12 blades. Despite the analysis were converged, pressure contour did not fit. I didn't try to create control points in mesh. I have to use pics. and animations for my result report. Visiual report must seem good. But I will try what you said. Thanks again for your advice. |
Error of the Ansys-CFX Fourier Transformation, in Transient Blade Row model | OREO | ANSYS | 0 | December 8, 2020 20:56 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
