How to set user points for volumetric flow rate[m^3/h] |
September 14, 2021, 01:49 |
Motofumi
I'm new to Ansys CFX. I checked the manuals and tutorials, but couldn't find the answer. I'm sorry if this question is very simple. I want to monitor the volume flow rate [m^3/h] at the inlet part when calculating the solver, so I made an expression to calculate the volume flow rate [m^3/h] in Expressions. The formula is this: abs (massFlow () @Inlet) / massFlowAve (Density) @Inlet * 60 [s] / 1 [h] However, when monitoring using this formula, the unit is [m^3/s] on the graph screen of user points. What can I change to monitor [m^3/h]? I look forward to your comments. Kind regards, Motofumi |
September 14, 2021, 07:56 |
Rep Power: 32 |
You cannot change the time units for a specific monitored quantity.
The ANSYS CFX Solver work in "Solution Units", see CFX-Pre/Edit Options, and select the units for the time dimension you want. Keep in mind that changing time from [s] to [hr] will change all the time-related quantities to be [hr] based instead of [s] based.
September 14, 2021, 10:19 |
Frank Weise
Rep Power: 17 |
If you are only interested in the value, you can use the following expression:
abs (massFlow()@Inlet) / massFlowAve(Density)@Inlet*1[hr]/1[m^3] |
cfx |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
set BC mass-flow-inlet via UDF and via GUI perform different result | sawa25 | FLUENT | 1 | February 25, 2015 00:51 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
