convergence problem higher outlet pressure than inlet |
August 27, 2021, 00:49 |
Marcin
Rep Power: 12 |
Hello
How correct setup boundary conditions: My Case I have two inlets - one 10 bar pressure , second 1.5 bar absolute pressure outlet - 2 bar absolute pressure. And thats is a problem that pressure over outlet is better than on inlet 2. And If I run steady state (ideal gas) My imbalances are high. My bc's Inlet1 - velocity inlet Inlet 2 - pressure inlet with total pressure Outlet - pressure outlet
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
August 27, 2021, 05:43 |
Rep Power: 143 |
Are you doing this in CFX or Fluent?
If CFX then please attach your output file.
August 29, 2021, 04:45 |
Marcin
Rep Power: 12 |
Yes Im doin in CFX
Convergence problem is that I have reverse flow on outlet and all gas is goin to inlet 2 .
August 29, 2021, 05:34 |
Rep Power: 143 |
As I said previously - If CFX then please attach your output file.
Also please attach an image showing the problem flow.
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Simple setup with mass inlet en pressure outlet but no convergence | Benoit85 | FLUENT | 2 | October 24, 2019 04:15 |
higher total pressure at inlet | motorbean | Main CFD Forum | 0 | December 7, 2011 16:13 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
