Honeycomb Porous medium
Old   August 25, 2021, 14:36
Post Honeycomb Porous medium
Ahmed Ibrahim Abdalla
ahmed ibrahim is on a distinguished road
Hello everyone
I'm working on a project to reduce the heat transfer in plate in a square pipe. i have to create a porous medium in this plate. my question is, how to define the honeycomb parameters in CFX ?
ahmed ibrahim is offline   Reply With Quote
Old   August 27, 2021, 05:21
Smile
can anyone help me please
Old   August 27, 2021, 05:44
Have you looked in the documentation and read what parameters CFX needs to define a porous region? I would have thought that was the obvious place to start.
If you have read the documentation - then what are you having troubles defining?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 9, 2021, 21:01
Question
Hello Ghorrocks,
thank you for your Answer. I have red the documentation and what parameters CFX needs to define a porous region. I understood that a Honeycomb or Perforated plat are Anistropic Porous medium and they could have Directional Loss Coefficient. Ialso have red some letrature about Honeycomb/ Perforated plate and i saw in some of them the Kperm was 5.73 mm/s ( which i couldnt implement in CFX ) and some of them was 1E-5,-6, -9 , -10 ,,,,,m^2 which i could implement in CFX.
I still dont understand how CFX understand that these numbers are for honeycomb or other thing.
one honeycomb can have many deffirent values.
how can i define it exactly to get the result i want.
Old   September 11, 2021, 06:40
siw
Stuart
siw will become famous soon enough
Do you have the experimental data for the pressure drop (\Delta p) across the plate as a function of volumetric flow rate (Q) or superficial velocity (U_{s})? This is the velocity associated with the volumetric flow rate and frontal area (Q=AU_{s}), not the true velocity within the porous media and the area of the filter pathways.
For a subdomain you can input permeability in units of [m^2] and loss coefficient in units of [1/m], but the latter might not be significiant. Let us assume you have a plot of \Delta p vs Q and curve fitted to give \Delta p=aQ+bQ^{2} which is also \Delta p=aAU_{s}+b\left(AU_{s}\right)^{2}. CFX-Solver Theory Gude explains the Darcy-Forchheimer equation. You can then determine your K_{perm} and K_{loss} from the curve fit, fluid properites (\rho and \mu) and filter thickness (\Delta n):
aA=\frac{\mu \Delta n}{K_{perm}} \\rightarrow \ K_{perm}=\frac{\mu \Delta n}{aA}
bA^{2}=K_{loss} \frac{\rho}{2} \Delta n \\rightarrow \ K_{loss}=\frac{2bA^{2}}{\rho \Delta n}
Use the directional streamwise multipler to ensure this is applied to the streamwise direction only.
siw is offline   Reply With Quote
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 17:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 21:18
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 04:07
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? Chander CFX 3 November 28, 2011 14:26
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
