Solid Timestep
Old   April 26, 2007, 16:58
Default Solid Timestep
ParodDav
I'm performing a heat transfer simulation both through solid bodies (conduction) and fluid (convection). Does anybody can suggest me a correct solid timestep to use for it?
Many thanks in advance !!! Davide
Old   April 26, 2007, 18:13
Default Re: Solid Timestep
If you are running a steady state model then the following might start you off:
[density(solid)*Cp(fluid)]/[density(fluid)*Cp(Solid)]
You can also adjust it during a simulation using edit run in progress. This way you can tune it while it is running for best effect.
If your simulation is transient then you cannot accelerate the solid timestep.
Old   April 28, 2007, 11:05
ParodDav
Dear Glenn, both your suggestions were really nice! Figuring out on several ways and following what you said, I found a good solution to my problem! Thank you very much! Davide
Solid combustion problem.... godspeedsam FLUENT 3 May 24, 2022 04:29
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 3, 2013 23:04
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
