May 15, 2007, 05:53 |
SST-DES modelling problem
I want to model the transient separated flow around a blunt body, e.g. a simple building model mounted on the ground using SST-DES model. In the meshing step, I estimate the minimun grid space y+ is about 10, and the grid growing factor is about 1.1~1.2. The parameters of the SST-DES model almost keep the defaults. During the iteration, the monitoring variables almost keep constant after several hundred iterations. After nearly 1000 time steps, I check the results of the blending function F2 in the post,and find that the LES region is very small. Only a small region after the building is calculated using LES, therefore, it could not obtain the transient flow structure around the building like the example given by CFX. I think the reason might be the grids in the detached regions are too coarse to active the LES.
1. Besides the method of refining the grids, could the parameter C_des also be decreased from the default value 0.61 to a smaller one since CFX adopt the multiplier of C_des and Delta(grid space) as the length scale? For the computation resource for me is limited, and the current mesh cells reach nearly 2 million. 2. Time step also affect the result. How to set the time step appropriately to aviod such problem? Thank you! |
May 17, 2007, 11:26 |
Re: SST-DES modelling problem
May 18, 2007, 06:22 |
Thank you,Joe! I have downlaoded the paper. I want to ask is there any detailed paper or document about the CFX DES simulation?
How to use DES well? | Daniel | Main CFD Forum | 0 | October 26, 2008 05:59 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
Problem with DES model | mehul | Siemens | 0 | April 12, 2006 08:01 |
problem about modelling fluidized bed! | xfish | FLUENT | 3 | November 6, 2003 08:42 |
modelling of conjugate heat transfer problem | ajay chandra | FLUENT | 1 | October 28, 2003 06:51 |
