2-way ANSYS-CFX FSI reaction force calculation on solid
Old   September 19, 2013, 04:57
Default 2-way ANSYS-CFX FSI reaction force calculation on solid
esbolico
esbolico is on a distinguished road
Hi Everyone,
I am doing an FSI simulation with ansys and CFX where I apply a displacement over a certain area of a pipe-like structure (where there is no fluid) and I want to see the behavior of the fluid and calculate the required force. Find attached a view of how my worbench looks like.
http://imageshack.us/photo/my-images/41/wj4l.png/
The question is how can I calculate the force that I have to exert on the solid part. I have read that you can calculate the force on the fluid surfaces using for instance force_x()@NameOfSurface but doing so with the name of the surface where the displacement boundary condition is applied returns 0 when it can't be that.
Thank you very much!
esbolico is offline   Reply With Quote
Old   September 20, 2017, 16:16
nina
masih is on a distinguished road
hi
can you find the answer? because i have this question too?
masih is offline   Reply With Quote
Old   September 21, 2017, 00:57
urosgrivc
urosgrivc is on a distinguished road
Are you sure your NameOfSurface is on the fluid side?
If I understand you just vant the force on the pipe than just use your fluid wall location as force on area is obtained from flow properties like Pressure and visqus forces like shear.
urosgrivc is offline   Reply With Quote
2-way, cfx, fsi, reaction force
Reaction Force calculation in solid part in 2-way FSI simulation with CFX esbolico ANSYS 0 September 17, 2013 08:54
FSI calculation error zhichao CFX 2 May 6, 2013 06:48
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
