[Sponsors] | |||||
#21 | |
William
Rep Power: 7 ![]() |
I made a plate model to use porous domain, but each plate has several semicircular channel, and some paper said Gnielinski or Dittus-Boelter equation well fits the experimental result. I set up the heat transfer coefficient in porous domain setting, I attached a figure for your better understanding. Resistance loss coefficient : friction factor / hydraulic diameter Heat transfer coefficient : Nusselt number * conductivity / hydraulic diameter |
#22 |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Shouldn't Nusselt number have a characteristic length defined in the flow direction along the plate, not the hydraulic diameter? See: https://en.wikipedia.org/wiki/Nusselt_number
#23 | |
William
#24 |
Good point. It looks like you have everything in place to model what you intend, you have answered all my questions
Just be aware that you are using empirical correlations for both pressure drop and heat transfer, so you can expect significant errors in both of them.So if we go back to post #1 and your original question - you asked about a problem with your heat transfer. Was the heat transfer results you showed using the porous flow results you describe and the Gnielinski or Dittus-Boelter correlation? Can you clarify what your question as I do not understand exactly what you are asking.
#25 | |
William
Instead, I used code calculation result that can calculate its heat transfer by nodalization method. The result is in the figure, the temperature variation of 'T_CO2_CFD_scale' is too weird. It means too high heat transfer coefficient in the left section. 'T_CO2_CFD_plate' is a result of 'thin material' assumption. My question is : why this too high heat transfer coefficient in porous-solid interface, when the 'free slip wall' condition is applied instead of 'no slip condition'. |
#26 |
I have no idea what that chart is showing, I do not know what heat transfer correlation you are using or how you have applied it, I have no idea what the "thin material" assumption is or how that is relevant.
This thread is very frustrating because you are not explaining what you are doing. I now know that: * You are using some form of heat transfer empirical correlation but have not said which one or how you applied it. * The fluid is supercritical CO2 * You are comparing between a scale model and a full sized device These are all vital bits of information which you have only revealed after dozens of posts on this thread. Why did you not say these things in the first post? What other vital information have you not revealed yet?
#27 | |
William
I'm sorry but I did not intentionally hide some information. I'm trying to explain this domain to you. Model : *Printed Circuit Heat Exchanger(PCHE) with 7 hot and 7 cold plates and 15 solid plate between each hot/cold plates, *Each fluid plate has 7 straight semicircular channels with D=1.8mm *Plate thickness is 1.2mm and semicircular depth is 0.6mm *Hot fluid is CO2 with 8MPa and Tin = 76C *Cold fluid is Water with 200kPa and Tin = 25C *Inlet and outlet header(distributor) is semi-cylinder shape. *I want to describe heat transfer of hot/cold fluid with solid plate, to compare flow distribution of some conditions. *It has too many channels, so I cannot use fluid domain because of computing cost, so I want to use porous domain. *In porous media correlation, there are two terms but only V square term is valid if Re>1 *So, Resistance loss coefficient is composed with (f/Dh) *At heat transfer setting in porous domain, there are 'fluid solid area density' and 'fluid solid heat transfer coefficient' *I used interfacial Area Density[1/m] -> (Surface Area / Total volume) and Heat Transfer Coefficient[W/m^2 K] -> (Nu * k / Dh) *The total model has error with heat transfer calculation, so I used thin material option in porous-solid interface setting I guessed heat transfer coefficient term in my handwritten calculation, so maybe I think it could be wrong. I really have no idea why this model shows very weird result (too high heat transfer coefficient at inlet section). If you need more information to understand, please let me know. I'm trying to explain everything I can but it is difficult to say it completely. |
#28 |
You have used many simplifications, such as using empirical relations (pressure drop and heat transfer), have complex material models (supercritical CO2), are not modelling the detailed fluid flow but are using simplified correlations. You have to expect that this will result in your model having errors, and in some cases big errors. You also seem to say that your heat transfer coefficient calculation does not seem to work so you used a thin material model - how are you going to get an accurate result when you use the wrong physics?
All I can say is that if you want an accurate result you need to use an accurate modelling technique, which is to model the fluid as a fluid domain and accurately resolve the boundary layer.
#29 | |
William
On the off change the flow distribution could affect heat transfer coefficient of core section, it could be right? I'm continuously trying to check the heat transfer coefficient, heat balance of inlet/outlet Temperature, thermal conductivity of solid.. but everything has no problem just for heat transfer quantity... |
#30 |
You really should check a model like what you propose against experimental data. You need to know what level of accuracy to expect from your approach as it is very unusual. I suspect you will find it quite inaccurate.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 03:55 |
| Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 20:24 |
| Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
| Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 18, 2014 00:45 |
| Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 03:18 |
