several type's Boundary condition
Old   January 4, 2022, 19:13
Default several type's Boundary condition
Jin Seok Lee
jins9158 is on a distinguished road
I am working about ventilation's system fan analysis
I want to get about mass flow data for CFD result because my senior want to know about performance difference by seeing mass flow data
So I am setting and Inlet is "Total Pressure", Outlet is "Static Pressure", rotation is applying.
When I see CFX guide book, I saw several boundary type and I couldn't understand
1. Most Robust
- Inlet [Velocity/Mass Flow] / Outlet [Static Pressure]
- Inlet total pressure is an implicit result of the prediction
2. Robust
- Inlet [Total Pressure] / Outlet [Velocity/Mass Flow]
- static pressure at Outlet and velocity at Inlet are part of the solution
3. Sensitive to Initial Guess
- Inlet [Total Pressure] / Outlet [Static Pressure]
- The system mass flow is part of the solution
4. Very Unreliable
- Inlet [Static Pressure] / Outlet [Static Pressure]
- Not recommend inlet total pressure level and mass flow are implicit result of the prediction
Why "Sensitive to Initial Guess"?
What difference does it make when calculated by an internal algorithm?
jins9158 is offline   Reply With Quote
Old   January 5, 2022, 13:39
Opaque will become famous soon enough
I think you are interpreting the information listed backward.
If the solution is well converged, that solution should be independent of the initial guess.
HOWEVER, if the initial guess is poor, there is no guarantee you can converge the solution; therefore, there is nothing to compare against.
Hope the above helps,
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   January 5, 2022, 16:55
Another way to look at it is that the list is in order of numerical difficulty.
Option 1 is the most numerically easy, so you should get the best convergence with this option.
Through to Option 4 which is the most numerically difficult, and you are most likely to have problems with convergence if you have set it up this way.
Old   January 5, 2022, 19:25
Jin Seok Lee
thank you for replying my question
So you mean if the convergence is good, all option's is ok?
Is it right?
Old   January 5, 2022, 19:29
Good convergence is one of many, many things which need to be right to have an accurate simulation. See FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
Old   January 5, 2022, 19:51
Jin Seok Lee
Thank you for answering my question
I saw link's information and I realized that I already knew information
So, I think you wrong my question
I want to know about the process's difference in condition of 4 option
The guide book just let me know that "1 option is very robust", "2 option is robust" briefly
I am wondering why in detail (for example, formulation's difference)
thank you for your concern
Old   January 5, 2022, 22:03
Opaque's comment on another thread is relevant here: Convergence Issue for Unsteady Compressor Simulations
Again, it all comes back to numerical stability. The different boundary condition combinations result in different system unknown variables to be solved. Some of these system variables are numerically easier to solve than others. (By system variable, I mean total flow rate, overall pressure drop and system level parameters like that)
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 08:03
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
boundary types don't appear in boundary condition menu stimpy FLUENT 0 December 15, 2010 03:33
