Write an expression for pressure at a point
Old   January 5, 2022, 09:26
Default Write an expression for pressure at a point
Mey
MNMK is on a distinguished road
Hello everybody,
I am simulating a water Tank in Transient. I would like the water flow at inlet reduce to Zero when the air pressure in the Water Tank (on the Top) reaches 3 bar. Therefore, I am trying to write an expression for pressure at a point to combine with mass flow at inlet. (see below)
AirP --> areaAve(Pressure)@User Point 1
INLET Massflow--> 0.05822[kg s^-1]*if(PAir<3[bar],1,0)
but It does not recognize the User Point 1.
May you give me a Tip or another solution?
Best regards,
MNMK is offline   Reply With Quote
Old   January 5, 2022, 13:30
Opaque will become famous soon enough
You need to show the error message you are getting.
It makes no sense to compute areaXXX()@Point.. Does a point have an area?
There is a function to probe the value of a variable at a point, read documentation for details, such as
MyPressureAtMyLocation = probe(Pressure)@Point
Now, as far as I recall "Point" must be a point locator created either as a source point, or an existing coordinate-based monitor points. I do not recall if expressions support "Ansys CFX Solver" user locations.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Monitor Point expression value different from same expression in CFX-Post dvanb CFX 3 March 13, 2018 16:51
Referencing a User Location for a Monitor point expression in CFX pre ct18 CFX 2 February 18, 2018 16:31
Outlet boundary condition in interFoam Andrea_85 OpenFOAM Running, Solving & CFD 51 July 20, 2017 13:31
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
How to request cfx to write variables at a point? Uday CFX 1 February 5, 2006 23:42
