June 26, 2007, 10:49 |
Split ICEM .tin files - how?
Hi all,
I've just imported a ParaSolid geometry into Icem. The conversion to a .tin file was successful, bit its about 90MB now. ICEM can't even load it over night any more. Do you know any tool or sth. to split an .tin file in to some more handy parts? Cheers and Thanks Bernhard |
June 26, 2007, 15:51 |
Re: Split ICEM .tin files - how?
I think it is easier to split up your original geometry, where the parasolid comes from. Do you have acces to that source?
Gert-Jan www.bunova.nl |
June 27, 2007, 03:02 |
A trial version of Rhino3D (30 saves) can handle and edit parasolid files. -Dr. Flow Squad http://tinyurl.com/2gkjh8
June 27, 2007, 04:39 |
Ok, thanks for your ideas!
I first tried to open the original geometry with SolidWorks, which can usually handle ParaSolid files, bit I had a problem with the ParaSolid version of the file - Solidworks couldn't open it. I'll try Rhino and tell you if it worked. Cheers, Bernhard |
June 27, 2007, 05:28 |
Parasolid files can be opened in Solid Edge,Solid Works,Pro-E,and in Design Modeller also. from these u can export to igs,stp or to any other format compatible to icem,try the one which gives smallest size in icem.
and in Icem divide it into parts,else u can split(see documentation),create two or more projects and finally u can have a ggi between splits in cfx. |
June 27, 2007, 08:41 |
Thanks Pankaj,
actually that's what I tried.. But Opening the Parasolid file in SolidWorks doesn't work in that special case because of the coding of the parasolid file (that's what the error message in SW says). I guess it's a problem with the versions. I've downloaded the Rhino demo to to the simlification and cleanup, just waiting for mail with the download link for the Parasolid plugin now.. Cheers Bernhard |
Gridgen files to ICEM CFD | hsadek | ANSYS | 6 | July 26, 2012 05:19 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
How can i read mesh files made with ICEM? I want use them for my own code | zmester | ANSYS Meshing & Geometry | 9 | October 11, 2009 07:18 |
Problems with result files | Kasper | CFX | 5 | December 14, 2006 02:41 |
Who know how to use the split edge in icem cfd? | carnivore | Main CFD Forum | 2 | December 16, 2004 23:32 |
