Jin Seok Lee
Rep Power: 5 ![]() |
I am working about rotation analysis about sirocco fan
I got "warning message" but I couldn't understand +--------------------------------------------------------------------+ | ********* WARNING ********* | | First side of interface | | Domain Interface 2 | | seems to contain a vertex at R=0 (Rmin/Rrange < GGI ETA TOLERANCE).| | This is not supported for Stage (Mixing-Plane) interfaces. | +--------------------------------------------------------------------+ I am concerned interface don't applied (now the analysis is process and convergence is good. but I think that "Mixing plane" interface was not applied) I searched my problem and I found out similar problem. The problem was solved by using "specified pitch angles" However, in my case, I already used "specified pitch angles" (reference my picture) Would you give me some ideas? Thank you to read my question Last edited by jins9158; January 14, 2022 at 01:44. |
Display Modes | |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
