Different magnitudes of pressure on each side of an interface in CFX
Old   January 23, 2022, 07:35
Exclamation Different magnitudes of pressure on each side of an interface in CFX
Levi
Levi8 is on a distinguished road
I'm working on a multistage pump which has rotary and stationary domains.
I set a (frozen rotor) interface between a rotary and stationary where it can calculate the pressure by massflowAve(Total pressure in Stn frame)@ side 1 and massflowAve(Total pressure in Stn frame)@ side 2.
The problem is that the pressures on both sides aren't equal and their difference is more than 30%.
Thank you for your help.
Levi8 is offline   Reply With Quote
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
