Good convergence but without a good heat balance
Old   June 27, 2007, 16:51
Default Good convergence but without a good heat balance
Juan Martin Catelén
Hello. I'm modelling a pool that is loosing heat trough a walls (one of them has velocity). Also, it has inlets of fluid with fixed temperatures and outlets where the temperatures are calculated. The problem I'm having is that although the residuals of the heat transfer are below 10-4, when I compare the heat entering to the pool through the temperature difference of inlets and outlets with the heat that is flowing through the walls, I see a difference of 20%. Is this possible with such a good convergence? What could be happening? The pool is of 22m long, 0.9m and 2.5m width. It has 750000 elements. I'll be waiting for help. Thanks in advance.
Old   June 27, 2007, 16:56
Default Re: Good convergence but without a good heat balan
opaque
Dear Juan Martin,
Are you doing the comparison manually, or looking at the imbalance in the ANSYS CFX Solver Manager?
Do you have any Fluid Solid domain interfaces? The heat transfer reports are a bit different when they are present.
Opaque
Old   June 27, 2007, 17:16
Juan Martin Catelén
I'm doing the comparison with the CFX-Post functions in the table viewer. I'm taking the enthalpies at the inlets and at the outlets and comparing the diffrence with the areaint applied to the walls that are not adiabatic. I don´t have solid fluid interfaces in the domain. What do you think? Should I continue the calculation?
Old   June 27, 2007, 18:38
If you are looking for good heat balances then you should add this to the convergence criteria. This is usually caused by not running the simulation for enough physical time so the inlet flow fluid has reached the outlet and established steady state. Sometimes the timescale for the temperature to settle out is far long than for the flow so the default convergence options stop the run before the heat profile has reached steady state.
Old   June 27, 2007, 18:41
Juan Martin Catelén
Thanks.
Problem of heat balance in Coal Boiler simulation DG FLUENT 9 December 25, 2008 20:57
Good book for heat transfer + FEA? Bren Main CFD Forum 0 November 24, 2008 19:54
Good CFD software for automotive heat exchanger Kiran Gaikwad Main CFD Forum 3 July 14, 2008 20:38
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
