CFXSOLVE in BATCH
Like Tree1Likes
  • 1 Post By Johnson
Old   June 21, 2007, 17:06
Default CFXSOLVE in BATCH
S.
When you are running CFX5SOLVE interactively, you have the option of editing the definition file while the job is running. Is there any commands or way of changing the defintion file while CFX is running in batch mode? For example, I am doing a problem involving natural convection. I am trying to slowly increase the Ra number (increasing it by chaning gravity, for example) until my solution converges at the Ra number I would like. So, if I am doing it interactively, I can watch the residuals and bump up my Ra number slowly while it is running. In batch mode, I have to stop it, change the parameter I want and start it up again. Thanks.
Old   June 21, 2007, 18:41
Default Re: CFXSOLVE in BATCH
You can load a run which was started in batch mode in Solver manager and edit it from there.
Old   June 23, 2007, 05:18
Johnson
There is a command :
cfx5control <directory> options
which you can use to edit, inject commands and optionally write backup files.
Type 'cfx5control -help' for details.
Regards,
Johnson
FluidViscosity likes this.
Old   July 4, 2007, 04:04
Pankaj
hi
As I know cfxsolver can run without solver manager i.e. in the background or in batchmode.
& therefore u can monitor run in progress by selecting its run directory and can edit run in progress in solver manager,no need to stop and restart.
Pankaj.
Run Multiple Files in Batch nickninevah STAR-CCM+ 6 October 12, 2017 06:17
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
Windows XP Batch file help needed DL123 Main CFD Forum 2 July 3, 2009 08:53
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 16:44
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 18:02
