June 19, 2007, 14:49 |
stretch in axisymmetric flow
I am trying to create a non-uniform stretch in a axisymmetric 2-d flow. I would like to increase the length scale in the axial direction, while keeping the length scale in the radially direction constant. I know that stretch only works for 3-d cases, but is there another way to perform this function? thanks, Justin |
June 19, 2007, 18:10 |
Re: stretch in axisymmetric flow
ICEM or Workbench? I assume you are talking about a hex mesh. What you are talking about is easily done in Workbench using a sweep and in ICEM-Hexa using blocking. Glenn Horrocks |
June 19, 2007, 18:11 |
I am using workbench with ANSYS 10.0
June 20, 2007, 02:58 |
I am not sure if this helps you, but if you already have a grid, you can also scale this non-uniformly in CFX-Pre. Use something like [10,1,1] to stretch your geometry by a factor of 10 in x-direction.
Gert-Jan www.bunova.nl |
Axisymmetric Flow around a hollow cylinder with an extended flair | JLight | OpenFOAM | 5 | January 28, 2013 12:11 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Test for a laminar flow in axisymmetric nozzle | Victor | Main CFD Forum | 0 | November 30, 2005 10:51 |
Convergence for axisymmetric flow | bl201 | Main CFD Forum | 5 | August 16, 2005 17:01 |
2D axisymmetric flow | Andreas Abdon | CFX | 8 | February 25, 2000 08:39 |
