July 1, 2007, 07:16 |
Boundary Conditions
Dear All.
I am trying to simulate a multiphase-multicomponent problem. In my problem there is a cylinder with two inlets ( each at upper and lower ends) and same way two outlets . Cylinder is continuously stirred. I know the mass flowrates at inlets. What conditions should I define at outlets? Awaiting for your valuable suggestions. Thanks. Sameer |
July 2, 2007, 01:22 |
Re: Boundary Conditions
you can give the static pressure at the outlet.
In CFX if u see u could see a valid combinations of BC just follow that. It would be better if ur able to determine the velocity at one of the outlet. U havent specified what kind of flow it is either sub sonic or supersonic. based on that too it differs |
July 2, 2007, 04:12 |
Hi Priya.
Thanks for your suggestions. The flow in my problem is sub- sonic. I know the velocities at both outlets; but will it be a robust combination if i define mass flowrate at inlet and velocity at outlet? Regards Sameer |
July 3, 2007, 00:55 |
rather than giving more robust condition robust condition solves better. I too have faced a similar kind of prob but with single inlet and 2 outlet. robust gives better
If u want to determine pr variation from the inlet its better to give total pressure at the inlet and velocity at the outlet and solve |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
