Convergence problem in rotating analysis
3 Attachment(s)
I simulated a double suction fan analysis and reviewed the results.
I wanted to know the discharge rate from a double suction fan, and then I found a problem. I applied 80CMH flow at the outlet as an analysis condition, and applied a total pressure of 0pa as an inlet condition. According to the law of conservation of mass, the flow rate at the inlet and outlet is the same at 80 cmh, but the flow rate discharged from the fan interface is 90 cmh, which is a strange result. Before that, I reviewed the following situations and judged that convergence was achieved, but it is a bit confusing.. When interpreting, I identified the following situations: 1. residual 10^-3 level 2. Inlet and outlet pressure monitoring 3. Imbalance less than 1% I seem to have applied the timescale(10^-5 level) to an appropriate level, can I get some advice on what the problem is? I attached output file and some image |
Thank you for replying my question I already tried it. I controlled auto time scale between 1 ~ 0.001. I think that the data error seems to have occurred between the interface faces. |
Auto time scale does not calculate fluid residence time. It is usually a lot smaller than that. So you will probably find the fluid residence time will lead to a much larger time step size.
I have checked your output file and your imbalances are fine. So the global conservation is OK - your mismatch between the inlet and outlet flow rates is likely to be caused by you calculating it inaccurately. I note that the simulation has poorly converged residuals and it seems to have been doing this for a long time. This FAQ discusses what to do about it: https://www.cfd-online.com/Wiki/Ansy...gence_criteria |
1) make sure you evaluate on Total Pressure, not on Pressure
2) The flow is probably not nicely aligned with the interface. This might lead to wrong results. Solely look to inlet and outlet, or at components normal to your interface, if possible. |
I cannot figure out what interface you are referring to since you are not referencing names in your output file.
However, when comparing mass flow across an interface be extremely careful with you are doing so on a frame change interface (rotor-stator / stator-rotor) with a reduced model. You must account for the pitch change across the interface. Since you are using periodic, I can easily assume the pitch ratio may not be 1. Mass Flow Side 1 = Mass Flow Side * (or / ) Pitch ratio depending on how you define your pitch ratio. |
Thank you for relying my question. your advice is good for me much you said that "your mismatch between the inlet and outlet flow rates is likely to be caused by you calculating it inaccurately." I think you misunderstand inlet and outlet mass is same, but interface mass is not same (reference 1 image) Mass flow of all location is same excep for interface about stationary domain and rotationary domain. So I don't quite uderstand. Although mass flow of inlet & outlet is same, interface is not same. Could I need to simulate unsteady condition? My computer resource is not good and I don't have time, so I want to simulate steady condition including periodic condition. |
Do you mean that the mesh is not good between face of interface about connection face? When I made mesh, I made same size about interface. |
Thank you for replying my question The number of impeller's wing is 46. so I set up '7.82609 degree' about pitch angle(360/46 = 7.82609). So, I think that picth change is not bad. |
The discretization only guarantees that Mass Flow on 360[deg] of Side 1 = Mass Flow on 360[deg] of Side 2 MassFlow_Side1_sector = MassFlow_360 / No sector Side 1 MassFlow_Side2_sector = MassFlow_360 / No sector Side 2 Code:
MassFlow_Side2_sector No of sectors Side1 |
Opaque has explained why your flow rate at the interface is not matching the inlet or outlet flow.
4 Attachment(s)
Thank you for relpying my question~ I am sorry to bother you, but I don't understand your advice well. I think we misunderstand each other. So I attached some images. I am very pleasure to get me advice to you I am very thank you and I hope to get advice again. Attachment 89229 image of Rotating domain Attachment 89230 image of interface (R1,R2 to S) Attachment 89231 image of interface (R2 to S) Attachment 89231 image of interface (R1 to R2, Periodic) |
I am scheduled to review your advice. Again, thank you so much. |
