[Sponsors] | |||||
hang yang
Rep Power: 5 ![]() |
I am performing a transient water and air multiphase flow simulation using CEL to initialize the phase volume fraction as follows:
Air volume fraction:step(z/1[m]-0.98-3.005) Water phase volume fraction: step(0.98-z/1[m]+3.005) However, floating-point overflow occurs during the first iteration, using the K-e model. If I switch to the SST model, this problem will not occur If I don't use CEL,I also won't have this problem However, I think k-e model can be applied to this problem. How can I solve it |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Does the error occur during definition of the initial condition or when it starts to iterate?
Either way, I think the problem is likely to be your initial condition. Make sure you define a sensible initial value for k and epsilon, noting that epsilon cannot be zero (it makes turbulent viscosity undefined), and k cannot be zero (it makes the epsilon equation undefined). In fact the k-e model is not very good for very low values of k or e, which is why it is not used for low Re number flows. The SST model is much better at low Re number. What Re number is the flow you are modelling? If it is a low Re then the k-e model is not suitable and will not work well (as you have found).
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 19:10 |
| interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 06:36 |
| NEW turbulence TRANSITIONAL model | giammy92 | OpenFOAM | 3 | June 30, 2016 10:47 |
| manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
| Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
