Cgns
Old   April 10, 2022, 04:21
Default Cgns
hang yang
yhddd is on a distinguished road
I am using CFX for transient simulation and want to get the data of the flow rate at the outlet interface over time. However, only CGND can be exported under the export function.
May I ask which software can be used to open this format file? Can I get the text file? Can I use Excel to open it
yhddd is offline   Reply With Quote
Old   April 10, 2022, 05:37
CGNS is an open CFD standard. Many packages can open it - theoretically. In my experience I have never got it to work for me and I use other formats to transfer between packages.
The easiest way to get a text file of your solution is to open the results file in CFD-Post and go File/Export, select the domain(s) covering the solution and the variables you want to generate. But be warned - even a very small CFD simulation will generate huge files using this method. So big you will probably fill your hard drive and/or crash CFD-Post or Excel.
To keep it manageable you will have to select a few points of small regions to export. Then just select the objects you want to export in file/export.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Issues with CGNS formatted mesh in SU2 jlwhelan28 SU2 5 February 13, 2017 11:48
[Gmsh] Cgns support for gmsh robyTKD OpenFOAM Meshing & Mesh Conversion 1 July 13, 2016 11:27
[ICEM] ICEM CFD and Gambit (CGNS) AshwaniAssam ANSYS Meshing & Geometry 1 February 17, 2016 06:04
writing link between two CGNS files t.teschner Main CFD Forum 1 February 4, 2014 10:26
parallel support with CGNS format not yet implemented kirkrich SU2 3 January 18, 2013 15:39
