hang yang
Rep Power: 5 ![]() |
I am running a transient simulation using CFX and want to get the data of the exit concentration over time. I don't want to save a lot of result files and then get the data through the post-processing software. Is there a way to save only the last result file of the transient, but also get the exit concentration of each time step
Rep Power: 145 ![]() ![]() ![]() ![]() |
Exit concentration over time:
Define a Monitor Point in CFX-Pre with an expression something like massFlowAve(Stuff.mf)@Exit. The monitor point will be available in Solver Manager as the solution progresses at each time step (or iteration if steady state), and will not require further post processing . Save only last time step: In CFX-Pre for output options, define a Backup and select the option "Delete old files".
#3 | |
hang yang
The command line cfx5mondata extracts it as well. Look in the CFX documentation for syntax for the command.
Display Modes | |
wind turbine - post processing | er_ijaz | FLUENT | 0 | September 30, 2013 05:28 |
Post processing in SAS SST | arunintn | FLUENT | 0 | June 8, 2013 14:12 |
post processing for CEL expressions | Niru | CFX | 0 | May 10, 2013 13:13 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
