error:wrong number of args?
Old   July 4, 2007, 15:38
Default error:wrong number of args?
miomio
hi, I just finished this geometry using ICEM-CFD 10.0, then I click 'file>mesh>load from blocking' to generate mesh. but it said 'error: wrong number of args:expected 4'. can anybody tell me what's this arg? and what should I do about it? thanks a lot.
Old   July 5, 2007, 00:54
Default Re: error:wrong number of args?
mic
I had a similar problem. After installing the ICEM-CFD update 10.0.1 it vanished. Ask the support for the update.
Mic
Old   July 6, 2007, 13:58
miomio
I'm using 10.0.1 now. the error still appears.
Old   July 10, 2007, 00:14
mic
Hi miomio,
i guess you have build a blocking topology in order to generate a hex-mesh. I checked the issue and I receive the message if the blocking was done with an old ICEM version and the mesh is generated with a newer version. It's surprising that you still receive the error. In my case it vanished using the update. Sorry, for not beeing of help to you.
Mic
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
