Interface Mixing-Plane
Old   May 3, 2022, 06:10
Default Interface Mixing-Plane
Mercurial
Techies is on a distinguished road
Hi guys, I'm working with 1.5-stage turbine. I'm using stage mixing plane between rotor and stator, options constant total pressure and specified pitch angles. Why the value of massFlowAve(Total Pressure) in the interface of rotating domain is different from that of stationary domain ?
Techies is offline   Reply With Quote
Old   May 3, 2022, 07:58
Opaque will become famous soon enough
Have you already accounted for the pitch change between the rotor and stator?
Which total pressure are you expecting to conserve across the mixing plane? A good read of the documentation seems the right thing to do.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   May 3, 2022, 13:49
Mercurial
So it's because the pitch angle ? All value is always different between 2 interfaces, right ?
Old   May 3, 2022, 15:43
Not only pitch angle, but that is a start.
Advice is to start simple and learn what the mixing plane is doing as you increase the LoD (level of difficulty)
1 - Can you match the mass flows across the interface? LoD = Trivial
2 - Can you match the "energy flow" across the interface? LoD = Medium
3 - Can you match the "total pressure XX" across the interface? LoD = Advanced
Guidelines for running a mixing plane with a centrifugal compressor Andrew2 FLUENT 0 December 15, 2019 12:50
Heat generation at the mixing plane interface EnricoDeFilippi OpenFOAM 0 January 17, 2019 14:37
Need help in muti-stage axial compressor simulation using mixing plane pchoopanya FLUENT 0 July 9, 2018 02:51
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
