problem with importing and exporting profile BC |
July 25, 2007, 15:54 |
I have a problem for both exporting and importing profile boundary conditions :
- First I'd like to export a Total pressure profile boundary condition. But when I try CFX tells me that the variable Total Temperature does not exist. In my problem rho and cp are constant so the total temperature is the same as static temperature (it's written in CFX manual). So CFX should have no problem. Why is that? - So instead I exported a velocity profile boundary condition (is it as good as a total pressure profile BC ?). Now I need to know how to be sure that this profile is gonna fit with the plane of the new geometry where I'm gonna import it (because the global plane of the two geometries are different and when I import and initialize the profile, a new plane (probably the reference plane of the geometry from wich I imported the profile) appears) Thank you in advance. |
July 25, 2007, 17:42 |
Re: problem with importing and exporting profile B
I just realized that I misplaced one word in my question. Sorry, I am tired and English is not my mothertongue !
"Now I need to know how to be sure that this profile is gonna fit with the COORD FRAME of the new geometry where I'm gonna import it (because the global COORD FRAME of the two geometries are different and when I import and initialize the profile, a new COORD FRAME (probably the reference COORD FRAME of the geometry from wich I imported the profile) appears)" |
July 26, 2007, 08:50 |
Hi Gui,
You can define a local coordinate system in Pre and use it with the boundary condition where the profile is to be applied. Regards, Robin |
Importing Rhinoceros 3d model to SolidWorks | george85 | FloEFD, FloWorks & FloTHERM | 21 | March 5, 2014 05:19 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
Exporting ICEM Tetra Grid to Fluent with Hexa-Core | Tim | Main CFD Forum | 4 | August 28, 2007 04:05 |
Exporting Fluent results and importing into StarCD | Jim Loebig | FLUENT | 0 | July 20, 2007 16:26 |
Problems with exporting and importing CAS files .. | Danny | FLUENT | 0 | September 16, 2005 10:47 |
