June 29, 2022, 05:09 |
Analysis method of spray mist in CFX
Takayuki SUzuki
Dear all,
I am trying to use CFX to do an analysis on how mist spreads when water is sprayed through a single nozzle into the air as shown in the figure, but the results seem to be wrong. Please advise. The model is a nozzle with a simple orifice geometry as shown in the figure. The main settings of CFX are as follows Domain Air: Continuous fluid Water: Dispersed Fluid (300 micron) Free surface model: Standard Fluids Pair Models: Surface Tension Coefficient B.C. Inlet: Total pressure (Volume Fraction, Air:0, Water:1) outelt:Opening (Volume Fraction, Air:1, Water:0) Since only water flows in at the inlet, water must be 100% in the nozzle, but the water volume fraction in the nozzle cross-section is not equal to 1. At the inlet boundary, the water volume fraction was completely 1. Note that we have not included a cavitation model, but the maximum flow velocity is about 10 m/s, so we do not expect cavitation to occur. Also, looking at the Air Velocity, the situation has a velocity distribution even inside the nozzle. Is the setting wrong to begin with? Any advice on the proper settings for how to analyze how 100% of the water flows into the nozzle and disperses into the atmosphere would be helpful. Thank you, |
July 4, 2022, 03:17 |
Gert-Jan
Rep Power: 27 |
1) You should initialiize your CFD calculations such that the whole nozzle is filled with water and the surrounding is filled with air. It looks lie you didn't do that.
2) The air velocity shows the velocity that air will have at any location, even it the volume fraction is 1e-10. The same for water velocity. This shows the the velocity for any volume fraction of water, even it would be 1e-10. I guess you are looking for superficial velocities. This is the Velocity*Volume fraction. You can find this variable when clicking on the "..." |
Fourier decomposition CFX Time Transformation Method | MarcoC501 | CFX | 0 | September 9, 2021 04:38 |
Water spray analysis in StarCCM+ | Felipe Lopes Ribeiro | STAR-CCM+ | 1 | August 26, 2019 06:09 |
what is the best method to learn analysis using star ccm? | vignesh_n | STAR-CCM+ | 3 | March 3, 2015 13:16 |
Pump Cavitation Analysis in ANSYS CFX | techCAE | CFX | 6 | July 3, 2013 06:37 |
Spray Analysis for a Dosing system | cfd_88 | STAR-CCM+ | 2 | November 17, 2011 12:22 |
