July 8, 2022, 06:12 |
Ejector boundary conditions
David Artemyev
Rep Power: 3 |
Who could help me with set up of initial boundary conditions for an ejector in ANSYS CFX?
I am trying to wet the following: 1. Primary nozzle (Boundary type - inlet): - Total pressure (stable) = 200 kPa, where reference pressure is 100 kPa; - Static temperature is 280 K; 2. Secondary nozzle (Boundary type - inlet): - Normal speed is 0.3 m/s; - Static temperature is 280 K; 3. Diffuser ((Boundary type - outlet): - Average static pressure is 90 kPa; The results (https://drive.google.com/file/d/1vIR...ew?usp=sharing) show that there is a pressure rate less than the pressure in the secondary nozzle inlet what is absolutaly incorrect. I would be pleased if you point me on correct boundary set up. Somewhere I read that the secondary nozzle must be set as opening boundary type but when I try it the primary flow comes in both directions. Thank you for your help in advance! |
July 8, 2022, 06:46 |
Rep Power: 143 |
FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
I do not know what you are modelling or what the boundary conditions are representing so cannot help you. I also do not know what you mean by "there is a pressure rate less than the pressure in the secondary nozzle inlet".
July 8, 2022, 07:00 |
David Artemyev
Rep Power: 3 |
[QUOTE=ghorrocks;831273]FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
Dear user, Please see the link to the file: https://drive.google.com/file/d/1AeT...ew?usp=sharing If you have any other questions, do not hesitate to ask me. |
July 8, 2022, 07:06 |
Rep Power: 143 |
I do not have time to look at your files. Please do not post to third party download sites, and post images directly on the forum (see https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F for how to do this)
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Boundary conditions for simulating a car during cornering | BBack | OpenFOAM Pre-Processing | 0 | April 12, 2020 16:18 |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 05:35 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
