Variables
Old   September 3, 2007, 04:12
Default Variables
selim
Hi I ran a transient simulation I am suprised that I didnt have most of the variables available in use in cfx post
What may be the reason? I couldnt reach Wall Heat Flux,Temprature,Pressure etc?
Thanks in advance Selim
Old   September 3, 2007, 18:18
Default Re: Variables
Did you select "selected variables" in the result file options in CFX-Pre? That is probably the cause.
Old   September 6, 2007, 10:51
Omer
Glenn is right. In the Transient output control try to select all the variables that you need as an output for Postprocessing them.
Or else, it would only store some default variable values.
ADDITIONAL VARIABLES LIMITERS N.P CFX 5 December 1, 2011 07:47
$FOAM_USER_APPBIN & LIBBIN variables not set rassilon OpenFOAM Installation 2 February 16, 2010 20:54
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
Saving variables on a user patch with physical coordinates Zoltan Turzo CFX 2 April 20, 2000 15:05
