CEL Expressions
Old   September 25, 2007, 12:03
Default CEL Expressions
Nick
Hi, I'm trying to implement a CEL expression in CFX post, and for some reason the function won't plot properly. I checked to see the minimum pressure to see if there was some strange negative value somewhere, and the minimum came back as 787868 [Pa]
But when I try to apply the following expression
loge(p/(101325 [kg m^-1 s^-2]))
I get this error:
The problem was:
LOGe-OF-NON-POSITIVE
The error occurs on sub-expression: loge(p/(101325 [kg m^-1 s^-2]))
Any idea why this is happening??
Old   September 25, 2007, 12:35
Default Re: CEL Expressions
CycLone
Try using "Absolute Pressure" instead of 'p', which is the relative pressure.
Old   September 25, 2007, 12:57
Nick
Unfortunately, I get the same result when I try using Absolute Pressure.
I don't really 'need' to see the plot, I just need to know that the function actually works so I can use it in a definition in CFX Pre. What I'm getting at, is that if I use the option in post to evaluate at a specific pressure, the function works just fine - No errors. It just fails when I try to plot it.
I guess what I'm asking is whether or not the function will work if I use it to define something in Pre.
Old   September 25, 2007, 14:54
CycLone
It should work. I would follow up the Post problem separately with support.
derivative in CEL expressions alinik CFX 103 April 19, 2024 03:54
Grouping expressions in CEL foo7 CFX 4 September 21, 2011 09:15
Time Step and CEL expressions for Mesh Deformation rbarrett CFX 3 July 6, 2011 10:13
Cel expressions RAMAN6089 CFX 13 November 30, 2009 23:17
Cel expressions for trasient problem Jervds CFX 0 March 4, 2008 10:03
