expression-based additional varibles
Old   October 3, 2007, 05:19
Default expression-based additional varibles
july
Hey I am confused about the expression-based additional variables in cfx11.0. In the documentation, it says that such kind of varibles can be difined, but however I don't know how to assign an expression right to the newly defined additional variable.
Thanks in advance.
July
Old   October 3, 2007, 09:08
Default Re: expression-based additional varibles
opaque
Dear july,
Insert the Additional Variable, select Undefined type. Goto the Domain you want the variable active, and select Algebraic expression. Type your expression on the widget. Done.
Hope it helps,
Opaque
Old   October 3, 2007, 22:28
july
Opaque:
Thank you so much for your advice.
I feel so shamed that I haven't look up
the widget carefully. However, thanks you
a lot.
But the widget is really diffucult to
find.
July
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
