October 1, 2007, 23:09 |
Streamwise Second Derivatives
I am doing simple laminar pipe flow with heat transfer. I assume the answer is no, but I am going to ask anyway.
I want to compare pipe flow with and without the streamwise second derivative in order to investigate Peclet number effects. Is it possible to turn off the streamwise second derivative in one of the directions? |
October 2, 2007, 12:01 |
Re: Streamwise Second Derivatives
Dear S.
In principle, No. However, if you setup the problem with anisotropic thermal conductivity you should be able to set the axial conductivity to 0. Have you read the paper by Hennecke, D.K. (1968), "Heat Transfer by Hagen-Poiseulle Flow in the Thermal Development Region with Axial Conduction", Wärme-und Stoffübertragung, Vol. 1, pp. 177-184. or try this link, http://www.nea.fr/html/science/repor.../chapter10.pdf Opaque |
October 4, 2007, 02:54 |
Thanks for the link to the paper. I guess I am doing something a little more complicated than just pipe flow, but nonetheless I needed streamwise second derivatives off to make a comparison.
More importantly, thank you for this clever trick! It is obvious, but I never thought of doing that. Thank you! S |
October 4, 2007, 03:16 |
Also, what about turning off the streamwise second derivative for the momentum equation?
Display Modes | |
UDM derivatives for - for EHD flow | Sandilya Garimella | FLUENT | 7 | September 9, 2013 04:17 |
Stability Derivatives | embolado | FLUENT | 0 | December 27, 2010 02:12 |
Can we have access temperature derivatives??? | behrang2009 | Fluent UDF and Scheme Programming | 0 | July 29, 2010 20:21 |
Calculating Second Derivatives | fluidsguy1001 | FLUENT | 0 | December 12, 2007 12:50 |
Conversion of cell velocity derivatives | Manoj | FLUENT | 0 | November 30, 2005 12:08 |
