Baffle in the cubical domain in design modeler |
October 9, 2007, 15:07 |
Hi every body
I like to setup 3 baffles in a cubical domain. I like these baffles hasn't any thickness such as surface; 3 surface in the cube. How can I do it in the ansys design modeler? Thanks eslam |
October 9, 2007, 18:26 |
Re: Baffle in the cubical domain in design modeler
This is called a "thin surface" and I think the gas lift reactor tutorial in CFX uses one. Glenn Horrocks |
October 10, 2007, 03:39 |
If you extrude the curve (open ended), you will get surface bodies, which can be used as baffles. If you are using closed curves, as Mr Horrocks suggested you can choose Thin Surface Option with Inward and outward thickness as zero. This will give you a surface of the closed curve. Regards Anantha |
October 13, 2007, 12:16 |
Hi thanks for your pay attention I extrude the open end line and I produce a surface but i cant send it to CFX-Mesh. in CFX-Mesh i cant see the surface. I dont need thin surface that told dear Glenn Horrocks. I want one surface inside a cube!!
October 14, 2007, 06:51 |
CFX Mesh does not use surface bodies, only solid bodies. You need to use the extrusion to slice the solid body such that you have your internal surface. In DesignModeller you will need to use the slice function. Glenn Horrocks |
October 15, 2007, 10:28 |
Hi Dear Glenn
It needs thickness? I can't setup it. Can you set up simple structure for me? I don't like thickness, if I have it, my mesh quality reduces and also my CPU time is very big. My E-mail: Kashi_58@yahoo.com Thanks Eslam Kashi |
March 16, 2018, 08:12 |
Solution
How I solved
Just put the Surface and the 3d Body in one Part in the Design Modeler and Import the Multibody-Part into the mesh module. You should see your Body with the inside Surface as a part of the Body. |
[Other] Connecting 3D bodies in Ansys Design Modeler | chipper | ANSYS Meshing & Geometry | 4 | January 25, 2018 09:45 |
Importing Points in Design Modeler | danh | ANSYS Meshing & Geometry | 5 | March 30, 2015 10:45 |
Design Modeler - need to insert baffle into flowfield | pstreufert | ANSYS Meshing & Geometry | 3 | August 31, 2011 18:05 |
Design Modeler not working | tan v | ANSYS | 0 | July 7, 2011 02:43 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
